Results 21 to 30 of 37
Thread: The MkIII DIY Thread
  1. #21
    Jan 2007
    Very useful double-din wiring table for those wanting to install aftermarket HU's:
    http://faculty.ccp.edu/faculty/dreed.../VW-Wiring.pdf
  2. #22
    Eastern suburbs of Melb
    Mar 2010
    Gold Coast, QLD
    Quote Originally Posted by thestu View Post
    this is an awsome reg fix, i have done this to both my back windows and works 100% still to this day, bout 6 months later
  4. #24
    Oct 2010
    I just replaced the back two broken electric window regs with hand winder jobbies bought off ebay.
  5. #25
    melbourne
    Here's how to recondition a failing coilpack, or repair a busted one, for a MkIII VR6. These parts are quite prone to failure and very expensive to replace with OEM parts.
    http://www.vwwatercooled.org.au/foru...air-64780.html
    Oh, and there's over 30 pictures there, so look out
  6. #26
    Dec 2010
    Northern Beaches, Sydney.
    Heres my cheap and cheerful audio install thread for a Mk3 Golf.
    http://www.vwwatercooled.org.au/foru...tem-65808.html
    ---------- Post added at 01:11 PM ---------- Previous post was at 12:08 PM ----------
    Heres a thread on how to replace your Mk3 VR6 coil pack for half the price!
    http://www.vwwatercooled.org.au/foru...ent-68605.html
  7. #27
    May 2013
    Orange NSW
    My daughter has a 2001 cab with a broken antenna. I have removed the glove box assy as the first step. I am guessing the inner guard needs removing to replace it at that point as there appears to be a mount for the bottom of the antenna attached to it. The other issue is how to remove the radio without breaking something so the new antenna can be plugged in. These are a bit different to the MK5, make that a lot different The radio has two small holes on each side and I am guessing that I need to insert something to release the holding mechanism.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
  8. #28
    Quote Originally Posted by greg32 View Post
    If it's like a mk4 use to pieces of wire bent into a U shape. You will need one U shape bit for the left and one for the right side of the head unit.
    Basically 2 tabs each side of the head unit that you need to move by pushing the wire against them to allow the HU to be free
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #29
    Mar 2014
    Bundoora, Victoria
    The radio is supposed to come with two U shaped tools. Since you don't have them, use wire from a coat hangar.
    I cut one up and made two U shapes. Then insert a U, one on each side and push them in. You should then be able to pull the whole unit out, not using the U shapes though.
    I did this successfully. However sometimes the latches don't move out of the way properly when you put the U in and it can be tricky.
    Past - '95 VW Golf MK3 VR6
  10. #30
    May 2013
    Orange NSW
    Thanks for the radio hint. I will get back to work
