vr6 = 5x100 with approx 30 offset
mk5 = 5x112 with approx 50 offset
no go unless you redrill or get adaptors.
gidday...
lookin' for some wheels to fit VR6, probably 17z....and on the cheap,
what stud pattern does a VR6 have?
will mk 5 wheels fit?
what other common audi/vw/anythign else stock wheels fit...u know somethign i might find cheap on ebay as ppl upgrade thier factory mags.
2x Caddy, 1x Ducato
awsome, tks for fast reply....what about the center hole, are there usually problems? i.e is it unusually big on the VR6?
and what if the offset is a bit bigger than 30? no probs right as long as the wheels fit in the gaurds?
how wide rubber can you go with a standard vr6 before u start scrubbing out people?
if you go too high offset the wheels will sit too far in under the guards and will most probably not fit due to hitting your suspension strut. you can use spacers to lower the offset and push them out a bit more.
2x Caddy, 1x Ducato
erm...ok, i assumed higher offset pushed wheels further out? i assumed wrong it seems??
so slightly smaller offset would be ok if it doesnt scrun but higher offsel will look anemic and might not fit?
here this should help you out. just when you are altering this picture in your head, the orange line (wheel spokes) is the fixed point and the barrel is the part that moves in and out with change in offset. i didn't understand 'til i saw this diagram either.
Attachment 3519
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
wicked that helps heaps....so how wide do ppl recommend going in terms of tyre size?
