Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: mk5 gti wheels fit a mk3 VR6? stud pattern?
    Jan 2008
    Melbun
    Quote Originally Posted by youraveragepunter View Post
    wicked that helps heaps....so how wide do ppl recommend going in terms of tyre size?
    205 45 16 should be correct for a vr6. you can fit that onto any wheel between 6" wide and 9" wide
    2x Caddy, 1x Ducato
    Jan 2009
    Drummoyne, Sydney, NSW
    Anyone tried WRX rims?
    right pattern but i think offset is 45?? to large offset?
    Jan 2008
    Cremorne, Melbourne
    yeah they are the right pattern but im pretty sure you need spacers for subaru rims, you will get tyre scrub on the inside.
    check this site out, you can do all the calcs yourself (where i got that pic from)
    http://www.1010tires.com/WheelOffsetCalculator.asp
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Sep 2006
    West Sydney
    Depending on the width, ET45 is tolerable. The stock BBS wheels are 6.5" wide, ET43. If the Subaru wheels are 7" wide at ET45, it'll just stick in towards the suspension an extra ~8mm or so compared to the stock BBS wheels, which isn't much. Make sure your tyre choice will bring the overall rolling diameter to the same as the stockies too. Size of the tyre can affect clearance as well.
    Look for "audi wheels" or "golf wheels" on eBay. Sometimes you might find Mk4 Golf, Audi A3 or Audi TT wheels which will have the same centrebore and stud pattern as the VR6. Direct fit! Best bet is to keep your eye out for the Mk1 Audi TT wheels - they're 17" and look pretty on the Mk3 as well.
    Jan 2007
    offset is too high, and the spoke design often doesn't help much either, I've tried.
