Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Mk4 02j shifter conversion?
    Mar 2012
    Central Coast, NSW
    I have a sneaky suspicion that one of the polo shifter boxes is a mk4 design but with mk3 mounts so you don't have to modify the tunnel to mount it up. Meaning you can more or less bolt it all in as a straight swap.
    Don't forget you'll need the reverse plug off a mk4 harness to go on the linkage tower. Unless you don't like to see when you're going backwards at night...
    Jun 2013
    Leichhardt, NSW
    Quote Originally Posted by anthony--t View Post
    Yeah, I've read somewhere the same, need a polo shiftier box and transplant so bolts straight in without having to re drill holes
    Jun 2013
    Leichhardt, NSW
    Ive read the same, I found this that may be of interest.
    VWVortex.com - DIY: 02A ---> 02J Shifter conversion for VR6/SLC Cars
    Ahhh forgot about that!
    Jun 2013
    Leichhardt, NSW
    hahaha
    Jun 2013
    Leichhardt, NSW
    pretty happy, just picked up a Mk4 2.0l (2001) shifter box, shifter cables, cable bracket, selctor tower and reverse light switch for $100. Just need to track down a Polo box housing, ground plate and selector arm with L bracket and im ready to rock n roll.. Anyone know of anyone who has one by chance?
    Mar 2012
    Central Coast, NSW
    That's cheap!... I paid about $350 or so from memory and then bought the o2j diesel geek sigma 5 short shift. I was over $550 into my shifter lol
    Jun 2013
    Leichhardt, NSW
    wow, feeling even better after hearing that. yeah, a quick search on gumtree looking for M4 wrecking showed one on VIC, gave em a call and the rest is history. The $100 includes shipping to Sydney as well. Pitty they werent wrecking any polos, would have worked something out as a bundle so to speak.. the search continues
    Mar 2012
    Central Coast, NSW
    if you've got the mk4 unit might as well just to the modification and throw it in.
    Jun 2013
    Leichhardt, NSW
    true dat!
