Results 1 to 7 of 7
Thread: mk3 wont start
    Dec 2012
    brisbane
    mk3 wont start
    hi guys just after some advise while I wait for a scan tool to arrive to hopefully get some codes.
    mk3 golf 2.0 agg 10/97 build date
    To start with I had a bad crankshaft sensor (insulation had fallen off and was causing a short). replaced with new one.
    second did an oil change and replaced breather from block to pvc. nothing to involved.
    when done tried to start and just cranked over, so check for spark from coil lead nothing.
    maybe bad crankshaft sensor so I unplugged it, turn key to on and ground out the centre trigger wire. I get injector pulse, throttle control but no spark.
    ok on to the control of coil I have power and ground on the 2 outside terminals and no voltage on the centre, led light on centre and ground crank over and still nothing? so tried centre to positive same result?
    to make sure coil was good unplugged ecm turned key on and ground pin 7(ignition control) bam spark.
    so in conclusion I have no out put from the ecm to control the coil but I have input to control injectors and throttle. tried a different ecm same thing.
    does the immobilizer have anything to do with spark control? why would it let the injectors fire?
    thanks guys any input would be greatly appreciated
    Aaron
    regarding the immo.. I have worked on one of these and from memory the immo stops the injectors but not the starter, so I don't think your issue will be the immo
    If there is any one in Adelaide with a MK3 if I can borrow the car for an hour I don't mind testing this... But I'm pretty sure it won't be the immo.
    Dec 2012
    brisbane
    cool thanks
    that is what I thought as you would not want all that fuel being sprayed
    cheers
    Aaron
    You said you tried a different ECM, I'm fairly sure the immo box is coded to the ECM so simply putting in a replacement one still wont work.. I think?
    When you had the second ECM in did you recheck the injectors? ( I don't think there would of been one if the above is correct)
    It could possibly be a faulty ECU not sending spark...
    Jan 2011
    Rooty Hill, Sydney
    Geeez pretty certain you far off the problem, 2lt engines are a pretty bomb motor!
    Look at the simple things.
    I got a very strong feeling it's the Mmmm (it's what ever the equivalent of a vr6 coilpack is for a golf gl engine).
    I think it's ignition coil.
    Dec 2012
    brisbane
    yes I think I did have injector pulse with second ecm but will try again and ignition coil is good. I am leaning towards a bad earth somewhere and this is why the ecm cant fire the coil?
    cheers guys
    Dec 2012
    brisbane
    ok so today I plugged in second ecm and I have control of injectors but after about 30 seconds nothing so I guess that is the immobilizer doing its thing.
    does anyone no which pins on the ecm are used to ground? and where they would be grounding? I am presuming there is more than just pin no.1
    cheers
