Results 1 to 3 of 3
Thread: Mk3 window stuck
    moogeybup Guest
    Mk3 window stuck
    Hi guys - the motor on the front left window has failed with the window in the full up position. The question is how can I remove the regulator and assembly when the clips on the window cannot be reached - normally the clips come into view through the door when the window is partially down.
    Have tried almost everything but can't seem to get any movement or space - the Haines manual is no help
    Any assistance would be appreciated - or if this has Been addressed on this forum please let me know - a search did not result in anything just then
    Many thanks
    Mar 2009
    gold coast
    Hey mate, I removed my regulators recently. Just reached up with a ring spanner, you only get about 1/8 of a turn at a time so need to be patient.
    moogeybup Guest
    I will have a go at it but will need to get some skinny ring spanners
    Thanks
