Before I removed the motor looked like this
Started the project after the turbo seals went
Sent from my HTC 2PS6200 using Tapatalk
Bought a backyard turbo mk3 build car now turning it into something a bit better, here is my 1996 mk3 vr6
Removed head to be cleaned up an new cams, valve spring an titanium retainers fitted
New 276 tt cams installed
New parts arrived,
Head spacer 9:1 Como ratio
Chains an guides
Sp short Runner
Stock vr6 block with all bolts changed to arp bolts
Motor assembly with new chains an new oil pump
Mk3 front swap with mk3 vento
Coil overs installed
More parts arrived
6262 precision ball bearing turbo
3inch atp downpipe
Sp sri fuel rail an throttle body adaptor
Bahn Brenner turbo manifold
Aem inline fuel pump
Starting to assemble motor
38mm tial external wastegate
Turbo installed
Progress is looking good
