Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Mk3 vr6t build perth
    Bought a backyard turbo mk3 build car now turning it into something a bit better, here is my 1996 mk3 vr6
    Before I removed the motor looked like this
    Started the project after the turbo seals went
    Sent from my HTC 2PS6200 using Tapatalk
    Removed head to be cleaned up an new cams, valve spring an titanium retainers fitted
    New 276 tt cams installed
    New parts arrived,
    Head spacer 9:1 Como ratio
    Chains an guides
    Sp short Runner
    Stock vr6 block with all bolts changed to arp bolts
    Motor assembly with new chains an new oil pump
    Mk3 front swap with mk3 vento
    Coil overs installed
    More parts arrived
    6262 precision ball bearing turbo
    3inch atp downpipe
    Sp sri fuel rail an throttle body adaptor
    Bahn Brenner turbo manifold
    Aem inline fuel pump
    Starting to assemble motor
    38mm tial external wastegate
    Turbo installed
    Progress is looking good
