Results 1 to 7 of 7
Thread: brake lights wont turn off
    Apr 2008
    NSW
    hey guys
    the brake lights on the vento stays on when i turn the car off. Even when the car is on and I'm driving as per normal, from the outside it'd seem as if I'm braking. The brake lights seem to stay on even when I turn off the car.
    For now I've disconnected the bulbs so that it wont drain the battery but any suggestions on how to fix this and what the cause of this may be??
    Dec 2008
    Sydney/Canberra
    Brake pedal switch.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2008
    NSW
    You're right. It was the brake light switch. I had a look and it was just dangling. The switch itself is fine. I tested it and it still works when I pressed down, it turned off. I think it just got loose somehow
    Any idea on how to re-attach it to the brake?
    Dec 2008
    Sydney/Canberra
    You push it back into the pedal bracket, and turn it to lock it in. Although, if its fallen out, the little tabs have probably broken off.
    '01 Beetle 2.0
    mine was sticking when i started driving the Vento as it had sat for too long.
    as above, was a push and turn job
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2008
    NSW
    would you be able to take a photo of where the brake switch is meant to hook up to? I seem to have two holes on the pedal itself so unsure which one it's mean to go in to?
    Also, it seems like the switch works in the way that when you press on the switch, the brake lights go off and when the switch is not pressed, the brake lights stay on, which then tells me that the default setting when attached to the brake pedal must be that it's pushing something against it in order for the brake lights to stay off? On either hole, I cant seem to get the switch anywhere near the pedal which will allow it to stay pressed, thus keeping the brake light off? Any ideas?
    ill try grab a picture over the weekend
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
