Results 11 to 20 of 24
Thread: MK3 VR6 owner Please
    has anyone figured out where the problem is with the crusie control , is it the stalk or something else ?
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Dec 2007
    Ermington, Sydney
    Aaron found an air leak in his lines which he fixed and now his cruise works; correct me if I'm wrong mate, I think that's what I remember reading/seeing lol.
    Jul 2007
    Canberra
    I have it and it works pretty well, sometimes u have to press the set button 2 or 3 times but no biggie. Just dust in the switch in mine .........I think.
    Forever blowing bubbles.
    I honestly have no idea what's wrong with mine as I was told by the previous owner that it didn't when I bought the car.
    I did find a site somewhere that gave you instructions on how to test the wiring loom for the cruise control to see if it's an electrical fault, need to found where i put that.
    Nov 2008
    Arundel QLD
    Quote Originally Posted by V®6 View Post
    I have mk3 gl my cruise control does not work did find on a site some where mentioned something about dodgy regulator and gave a wiring diagram on how too wire in a new one
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by migolf View Post
    You should really test the system for faults before you add new things to a problematic system...
    Dec 2006
    Kilsyth, VIC
    Yep, fixed an air leak and mine works passably now. Not perfect, sometimes it take a couple of goes to start (which could be the switch) and it doesn't always resume (so you need to reset the speed) and ocasionally you hit a bump and it turns off. But haing said all that it works 99% of the time.
    For some reason VW decided they had lots of spare vacuum pumps so thought putting them into the Mk3 would be a good way to get rid of them. They also decided to make things interesting by putting all the tubing and pumps in the least accessable places. Seems the designer was feeling particularly malicious that day...
    Anyway, to "test" the system I would recommend this:
    Phase 1:
    1. Turn it on. You may or may not hear a relay "click" when you do that.
    2. Tap the brake or clutch pedal, you should hear a "click" when the relay turns off.
    In short your testing to see if the electrical bits are doing their job. If you do hear these clicks, excellent, move to phase 2. If you don't hear the clicks, either your not listening right or your cruise is well buggered.
    You can try cleaning the contacts in the stalk, but failing that I don't know.
    Phase 2:
    1. Pull our the washer bottle.
    2. Pull out air pump... it's wedged nicely behind the front quarter in a hole that like ripping your figers apart.
    Give it 12V and see if it runs, if yes, move to phase 3, if no, give phase 3 a bash anyway before bothering with a replacement pump.
    Phase 3:
    Grab the vacuum hose and suck like mad, you should be able to tell if there is a leak from here. If you think it's working have a mate feel the accelerator pedal since thats what it's pulling down. If it's moving, hook it all back up and hope for the best.
    Good luck finding the leak. The pipes run past the battery and into the front arm/rail thingy on the passenger side, from there I assume through the firewall and to the pedal. Most of this you can't get at. I was lucky and the crack was *just* as it goes into the rail so I was able to cut/patch/replace some piping to get it going.
    Electrics would be hard if it's anything other than dirty contacts.
    Pump is easy enough to replace.
    Leak in the line looks hard, but you never know, I didn't have to find out just how hard. Another option would be to get completly new air line and run a seperate linr yourself and hook it up. I had to do this to get the air con recirculate valve working again without removing the entire dash so it's possible.
    Nov 2007
    Mine works, but only once in a blue moon!
    Now owns a golf. Stoked.
    Sorry to hijack the thread but out of curiousity does anyone's little torch on their key work anymore??
    Dec 2006
    Kilsyth, VIC
    I had one that worked, but only because I bought a brand new key...
    It's the bulbs that go, but I haven't found replacements.
