has anyone figured out where the problem is with the crusie control , is it the stalk or something else ?
cheers brenton
Printable View
cheers brenton
Aaron found an air leak in his lines which he fixed and now his cruise works; correct me if I'm wrong mate, I think that's what I remember reading/seeing lol.
I have it and it works pretty well, sometimes u have to press the set button 2 or 3 times but no biggie. Just dust in the switch in mine .........I think.
I honestly have no idea what's wrong with mine as I was told by the previous owner that it didn't when I bought the car.
I did find a site somewhere that gave you instructions on how to test the wiring loom for the cruise control to see if it's an electrical fault, need to found where i put that.
Yep, fixed an air leak and mine works passably now. Not perfect, sometimes it take a couple of goes to start (which could be the switch) and it doesn't always resume (so you need to reset the speed) and ocasionally you hit a bump and it turns off. But haing said all that it works 99% of the time.
For some reason VW decided they had lots of spare vacuum pumps so thought putting them into the Mk3 would be a good way to get rid of them. They also decided to make things interesting by putting all the tubing and pumps in the least accessable places. Seems the designer was feeling particularly malicious that day...
Anyway, to "test" the system I would recommend this:
Phase 1:
1. Turn it on. You may or may not hear a relay "click" when you do that.
2. Tap the brake or clutch pedal, you should hear a "click" when the relay turns off.
In short your testing to see if the electrical bits are doing their job. If you do hear these clicks, excellent, move to phase 2. If you don't hear the clicks, either your not listening right or your cruise is well buggered.
You can try cleaning the contacts in the stalk, but failing that I don't know.
Phase 2:
1. Pull our the washer bottle.
2. Pull out air pump... it's wedged nicely behind the front quarter in a hole that like ripping your figers apart.
Give it 12V and see if it runs, if yes, move to phase 3, if no, give phase 3 a bash anyway before bothering with a replacement pump.
Phase 3:
Grab the vacuum hose and suck like mad, you should be able to tell if there is a leak from here. If you think it's working have a mate feel the accelerator pedal since thats what it's pulling down. If it's moving, hook it all back up and hope for the best.
Good luck finding the leak. The pipes run past the battery and into the front arm/rail thingy on the passenger side, from there I assume through the firewall and to the pedal. Most of this you can't get at. I was lucky and the crack was *just* as it goes into the rail so I was able to cut/patch/replace some piping to get it going.
Electrics would be hard if it's anything other than dirty contacts.
Pump is easy enough to replace.
Leak in the line looks hard, but you never know, I didn't have to find out just how hard. Another option would be to get completly new air line and run a seperate linr yourself and hook it up. I had to do this to get the air con recirculate valve working again without removing the entire dash so it's possible.
Mine works, but only once in a blue moon!
Sorry to hijack the thread but out of curiousity does anyone's little torch on their key work anymore??
