Results 1 to 10 of 13
Thread: Mk3 Vr6 idle canister????? help
    Apr 2010
    Werribee, Vic
    The little black canister that is attatched to the idle stepper motor and throttle body is busted,
    do I need to replace it with a new one or is there a mod that can be done?
    Apr 2010
    Werribee, Vic
    Ok just found out that this is called a "Charcoal Damper"
    Anyone had worked with these before??
    Feb 2008
    mOOROOLBARK
    yeah mate i have a near new one i deleted paid 100 for it new, can have it for 30 if you pick it up
    Apr 2010
    Werribee, Vic
    Quote Originally Posted by mk3pete View Post
    How did you delete it? big job?
    Whats your location?
    Feb 2008
    mOOROOLBARK
    im in mernda but it isnt hard to do i made up my own stainless intake http://www.vwwatercooled.org.au/f47/...-32201-12.html
    but you can make up some sort of connection with the right fittings and hose
    Apr 2010
    Werribee, Vic
    Which ports need to be interconnected?
    Do you still use the idle stepper motor or did you delete this also?
    Nice pics Thanks for your help on this pete.
    Feb 2008
    mOOROOLBARK
    yeah you still need the isv
    come from the manifold
    into the side of the isv then join the strait to the intake boot
    no worries dude
    Apr 2010
    Werribee, Vic
    no worries dude
    Hey mate, i did this mod on the weekend and it was running fine then i started having a problem with it stalling now.
    I sprayed the ISV with WD40 and that seemed to work but now it's stalling again, is this a tell tale sign of a worn out ISV?
    I hope not.
    Feb 2008
    mOOROOLBARK
    does it stall only when its cold?
    Apr 2010
    Werribee, Vic
    Nah just randomly all the time. it didn't do it for 2 days when i sprayed it. just thought it was sticking
