Make sure the car is level
You installed the thermostat with the pin hole at the top?
Make sure the heater is on max hot during the flush and warm up
After running the engine and the temp gauge reaches ~90 turn off but leave the ignition on
The electric water pump often kicks in and helps the bleeding process
