Results 1 to 4 of 4
Thread: mk3 vr6 control arm - can thy be replaced with r32 versions
    Mar 2007
    QLD
    HI there VWW crew,
    I need to replace the rear control arm bushes on my VR6 and have heard that you can replace them with r32 versions (supposedly the rubber centre is solid, without a few chunks cutout either side)
    I am pretty sure it s the mk4 r32, can anyone confirm this and i possible a part number. I have also heard that you can use TT versions but the centre is sloppy - I dont want to have to make up sleeves.
    Direct replacement is definitely preferrred
    Cheers,
    Courtney.
    Jun 2011
    R32 rear bush and poly front is the best/long lasting combo
    Awd TT and r32 bushes are the same.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2007
    QLD
    Thanks guys, on their way..
