Results 1 to 6 of 6
Thread: Mk3 VR6 Abs removal
    Apr 2013
    Melbourne,vic
    Mk3 VR6 Abs removal
    Hey guys, As the title says, has anyone done it?
    i have just acquired a VR racecar and the abs has been removed due to being unpredictable.
    It still retains the stock master and booster
    i am fitting a manual bias valve and getting rid of the factory proportioning valve.
    Do i need to swap the booster and master with a GL mk3 unit or can u run the existing master and booster?
    Any one who has experince in this i would appreciate your input!!
    Nov 2015
    If my memory serves me correctly, a Mk3 GL was fitted with ABS as standard (which my 96 Vento GL has), a Mk3 CL was not fitted with ABS (which my 97 CL does not have). Not sure how the CL brake master and booster would go with trying to stop a VR6 (beyond my level of amateurish tinkering).
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Jun 2011
    I've ran all the abs pump/lines with ecu and sensors removed. Was fine.
    Currently have a mk2 vr with no abs pump etc, but vr prop valve in back.
    Apr 2013
    Melbourne,vic
    Sounds promisingthink it will be a bit of trial and error.
    Got the VR beam and prop valve in the back, no pump etc.
    cant recall what booster I ran, seems ok, but not great. think thats more to do with brakes needing a bleed, new pads in the rear, and mismatch front pads and rotors
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
