Results 1 to 10 of 10
Thread: "Mk3 stock headlights"
    Sep 2006
    gold coast
    Lightbulb "Mk3 stock headlights"
    Hi, I recently got a 95 golf gl and the stock headlights seem to be really underpowered kinda like the 2.0L its got lol. Before the golf I had a land rover disco and the head lights where more than adequate so ive been driving in semi blind state since switching over, anyway im wondering if anyone here has changed their headlights to aftermarket types? or changed the bulbs in them to make them more powerfull? Cheers, also I must say being a first time poster these forums have some great info
    May 2006
    Your right. VW cars have always had lousy lights. I think you'll find its more about voltage drop than bulbs. A couple of relays behind the lights is probably going to make the most improvement. Anyone?
    Apr 2006
    Carlton, VIC (HK now)
    How bout some grounding cables?? Won't they do any good? I mean its overall performance... mine's getting foggy so i took it apart gave it a clean a seal it back
    Apr 2006
    Hobart,Tas
    I have always relayed the headlights on my golfs (apart from the mk4 and 5)
    That way you can go larger wattage globes without burning out the switch. By relaying them you are assued of gatting battery voltage. The difference is astounding! If your GL has the twin reflector setup the you could go to 120watts on the highs and whatever on the lows. Single reflector, I would go 90/130s Make sure they are relayed first though. Cheers, Andrew
    brackie Guest
    Relaying
    Syncro (Phill Lander) wrote an excellent description of how to do this to a Mk2. Maybe we could talk him into doing the same for a Mk3
    http://www.vwwatercooled.org.au/newf...read.php?t=283
    Feb 2006
    Camberwell, Victoria
    If you want great lights, grab a pair of Hella Celis mk4 look lights with HID kit.
    www.tmtuning.com sells them, although pricey, they will probably provide the best lighting possible!
    And remember, Hella can be trusted, because that's who make OEM stuff...
    Sep 2006
    gold coast
    hey thanks for the info, think ive got a few ideas cooked up now, might try relaying them and changing the globes providing there not too expensive
    ovw251 Guest
    loose reflectors
    Dear Group
    only new to the forum and purchasing a mk3 cl 3 door and when I took it for a check at Werners in Cairns they informed me it would need new HL's due to the fact that the reflectors were broken away inside , also some of the tabs connecting the lights to the car were broken, maybe this could be a similar problem Cheers Holger
    Sep 2006
    West Sydney
    Common problem with our headlights. The tabs are made out of plastic and are quite thin too so are prone to breaking. I've pulled apart a few headlights and only one came out to be still intact.
    Feb 2007
    Perth, WA
    Quote Originally Posted by Sands View Post
    ...so ive been driving in semi blind state since switching over...
    Short answer: **** headlights.
    I swapped mine out for Hella Dual Round projectors. MASSIVE difference. Easily 3x the light output with the exact same wattage bulbs as the stock headlights.
Similar Threads
  1. HAs anybody changed the stock Gear knob thingy?
    By Shade in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 24-01-2007, 12:03 PM
  2. VR6 Dyno Results with stock and custom exhaust
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 01-05-2006, 10:56 PM
  3. Stock, lightened aluminium or lightened steel Flywheels ?
    By aussieg60 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 08-03-2006, 09:36 AM
  4. back to stock
    By GoLfMan in forum Mk1 Golf
    Last Post: 02-12-2005, 11:35 AM
