Want a lit of his mods...
I'm sure he won't mind if i post them...
Thanks Matt...
VW 12V VR6 2.8 Golf 1994
• Stripped;
• welded cage;
• fire extinguisher;
• Sparco evo seats;
• Willans six point harnass.
Engine
• CCH ported and polished Big Valve Head (42mm inlet valves);
• Schrick Variable Geometry Intake, thermal coated by a firm in the US, Microcoat Thermal Barriers;
• Schrick 268 cams and high lift springs;
• BMC Carbon Dynamic Airbox with relocated carbon canister;
• Setrab 16 bar oil cooler;
• Mk IV VR6 head gasket (compression 10.5:1);
• Stage IV Turn2 engine mounts;
• Turn2 lightened crank pulley; and
• ARP studs.
Suspension
• Koni coilovers (recently overhauled to race-spec) lowered 30mm;
• Whiteline 22 mm adjustable rear sway;
• VW motorsport control arm bushings;
• Autotech front upper stress bar;
• Autotech Lower front stressbar;
• Autotech front a-arm bushings;
• Autotech upper Rear shock tower bushings;
• Autotech polyurethane steering rack bushes.
Brakes
• 332mm R32 front discs (slotted) and R32 calipers stock pads;
• Cooling ducts;
• EBC slotted rear discs; and
• Goodridge steel braided brakelines.
Transmission
• Peloquin Limited Slip Differential;
• 3.94 ring and pinion;
• Spec Stage II clutch & lightened flywheel (10lbs);
• Scorpion backbox with no other muffler or resonator;
• Turn2 transmission mounts; and
• Dieselgeek short shift kit.
Lights
• Hella Dual Rounds; and
• Phillips H2s 4100k HID globes.
Wheels
• VW Bravos.
