Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 118
Thread: Mk3 Race Cars...
    Aug 2006
    Melbourne VIC
    Mk3 Race Cars...
    Today when i was sitting in Physics watching the world go by i started thinking has any one on here or know of any body who as built a Mk3 Race car because to my knowledge the only one has been the F2 rally Car driven by Simon Evans and there was a quy with a VR6 racing in the NSW Sprint series any others circuit racing Mk3's? Tell us what your thoughts and knowledge are and pics are good too and even better some lap time and power out puts...
    Cheers James
    P.S I need more ideas to dream about in English on friday
    Sep 2006
    West Sydney
    Quote Originally Posted by Water Boy
    Design your take on a Mk6 Golf
    Sep 2006
    Parkinson / Brisbane
    one here in the build
    Aug 2006
    Melbourne VIC
    My take on the Mk6 mite please VW... Wat you building KI11Z???
    There has to be some Mk3 race cars out there some where...
    Cheers James
    Sep 2006
    a tracker with any luck . . . its stripped, has sparco evo buckets, willans 6point harness, b&m short shift, ultra light 17x7 wid 225/35z. next is cage, coilovers and lastly lotsa N/A engine mods turbos a cop out
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by KI11Z
    NA all the way... You cant bet the roar of NA induction full raw down the strait... Pulling hug revs...
    Cheers James
    blackgti1.8 Guest
    You want a good MkIII racecar?
    This is my favourite
    There was a article in a recent mag about it actually...
    http://videos.streetfire.net/video/5...91FC9ED3B3.htm
    http://videos.streetfire.net/search/...CD240376EE.htm
    Point Cook, Vic
    MDTs vr6 is the most race prepped mk3 i know of at the minute.
    FOLLOW US ON FACEBOOK
    Sep 2006
    MDT?! who/wat is that?
    Feb 2006
    Camberwell, Victoria
    Want a lit of his mods...
    I'm sure he won't mind if i post them...
    Thanks Matt...
    VW 12V VR6 2.8 Golf 1994
    • Stripped;
    • welded cage;
    • fire extinguisher;
    • Sparco evo seats;
    • Willans six point harnass.
    Engine
    • CCH ported and polished Big Valve Head (42mm inlet valves);
    • Schrick Variable Geometry Intake, thermal coated by a firm in the US, Microcoat Thermal Barriers;
    • Schrick 268 cams and high lift springs;
    • BMC Carbon Dynamic Airbox with relocated carbon canister;
    • Setrab 16 bar oil cooler;
    • Mk IV VR6 head gasket (compression 10.5:1);
    • Stage IV Turn2 engine mounts;
    • Turn2 lightened crank pulley; and
    • ARP studs.
    Suspension
    • Koni coilovers (recently overhauled to race-spec) lowered 30mm;
    • Whiteline 22 mm adjustable rear sway;
    • VW motorsport control arm bushings;
    • Autotech front upper stress bar;
    • Autotech Lower front stressbar;
    • Autotech front a-arm bushings;
    • Autotech upper Rear shock tower bushings;
    • Autotech polyurethane steering rack bushes.
    Brakes
    • 332mm R32 front discs (slotted) and R32 calipers stock pads;
    • Cooling ducts;
    • EBC slotted rear discs; and
    • Goodridge steel braided brakelines.
    Transmission
    • Peloquin Limited Slip Differential;
    • 3.94 ring and pinion;
    • Spec Stage II clutch & lightened flywheel (10lbs);
    • Scorpion backbox with no other muffler or resonator;
    • Turn2 transmission mounts; and
    • Dieselgeek short shift kit.
    Lights
    • Hella Dual Rounds; and
    • Phillips H2s 4100k HID globes.
    Wheels
    • VW Bravos.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Mk3 Race Cars
    By Water Boy in forum Mk3 Golf & Vento
    Last Post: 30-12-2008, 02:43 PM
