Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 118
Thread: Mk3 Race Cars...
  1. #71
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by mk1turbo79 View Post
    Here is one from Aus for ya, ignore the LHD bit.
    edit:
  2. #72
    Aug 2006
    Melbourne VIC
    Mmmmmmmm:
    Chris Eyre is my hero
    Quote Originally Posted by Chris Eyre View Post
    A bit of an update.
    Ages ago I'd arranged to go and see Ken Lark, who owns the car now, and have a good look through some of the fine VWM / Frazero parts that he has amassed over the years. He knew the late Richard Lloyd, so the odd Audi BTCC wing and wheel lying around just gives a hint of what he's seen.
    Anyway, this car is now painted silver:
    It's got a bit of Golf A59 or the TDI racers about it.
    Airjack inlet, just below the light ^^
    Speedlines as mentioned above, ETs pushing things to the max, and the wings are tugged outwards:
    Believe it or not, that is full droop!
    Proper race Brembos in the front, same type as the Reeves use:
    Shortblock 2.0 litre engine, RPM stamped in the usual engine plaque position, bearing out what's mentioned above about it:
    The shell is something else mind:
    Seam welded conspiciously. Exquisite cage in there. Note the curved bar, behind the drivers seat, curved just to create extra room for the seat. On the other side, the bar is straight. Also twin tanks fitted, clearly for endurance, one below the rear seat area, another behind the axle.
    Shell plaque found near the base of the B-pillar:
    On the A-pillar:
    This name looks like the co that created it, as the chassis number matches the initials:
    I wonder if HPR has heard of them? Looks like a 1997 car at best guess from the chassis no. Came out of Austria, but rumours of Sweden also.
    Some of the detail mentioned earlier in the thread...
    Dogbox fitted, with flatshift working on a VWMS lever:
    - apparently it's adjustable for testing, so the rpm cut out lasts longer when you're in less of a rush.
    - edit: note extended cable pick up at the base, altering the pivot effect.
    Rear axle:
    Note blade adaptor, rose joint drop link ^^ Also evidence of flat flooring going on with fuel tank underside contours x 2.
    Shown same but different on this spare axle - stud welded on back edge:
    Looks like a little front roll bar which has been adapted to fit this axle:
    Axle mounts:
    Dribble. Silver [:y:]
  3. #73
    Aug 2006
    Melbourne VIC
    Some of the '97 spec Mk3 TDI cars have been found in Italy. Mmmmmmmmm.
  4. #74
    Jun 2011
    What a find. Is there any specs around on them?
    Content:
    "I only post on Facebook if I know i am going to get likes" - M
  5. #75
    Sep 2006
    them air jacks.... wicked!
  6. #76
    Sep 2006
    A website you race junkies might like to visit: http://allracingcars.com/
  7. #77
    Sep 2006
    Aug 2008
    Rowville, VIC
    Campbelltown NSW
    Quote Originally Posted by Water Boy View Post
    and there was a quy with a VR6 racing in the NSW Sprint series any others circuit racing Mk3's?
    Im picking up this car later this week then off to a circuit club track day next monday
  10. #80
    Mar 2012
    Central Coast, NSW
    Quote Originally Posted by AtlasMk2 View Post
    I had my eye on that on eBay then it disappeared. Good value for money if it's the black car I'm thinking of.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Mk3 Race Cars
    By Water Boy in forum Mk3 Golf & Vento
    Last Post: 30-12-2008, 02:43 PM
