Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
Thread: Mk3 R32 v2
    Jun 2011
    Mk3 R32 v2
    This is for those who don't know, are sick of reading threads on plastidip and just want to kill some time. Enjoy.
    It all started a few months back when i was fed up with vag cars and couldn't wait to leave it all behind. Then a cheap R32 motor came up for sale and thought F@!k IT. Let's do it again properly this time.
    So picked up the motor one day after an all nighter at work.
    And from there began hoarding parts/looking for an acceptable donor car. The guidelines for the donor were minimal doors, amd cheap as possible. After looking at a few overpriced examples and ones that needed painting too this one popped up at a reasonable price.
    Having a heap on for the next few weekends i was nervous i wouldn't be able to secure the car. Sent a deposit and dude was happy to wait a few weeks till i could get it.
    After a few months of collecting bits and pieces and working out what route i was going to take. Things have started to make a progression.
    Stripped interior, removed most of the sound deadening, sanded and rust converted the floor, carpets back in and vr6 seats in.
    I've always wanted these jahre belts and i could never justify the cost but a set came up cheap ish so jumped on them. Along with the Handbrake too.
    The important stuff could start this week with the arrival of these baddies
    272/264 cam's.
    Armed with a box full of goodies from ecs plus some other things i started messing around pulling down the 12v for the necessary parts to make the 24v work in the mk3 bay.
    The motor is getting new chains and guides, 550cc injectors, the camshafts, 90A alternator from the 1.8cl, 12v cooling system(crack pipe, thermo housing with low temp thermo, all coolant lines) IE egr delete and whatever else i have forgot to mention.
    Jun 2011
    This thread will be scattered and half missing as i wasn't intending to make one.
    The specs of the motor:
    Mk5 R32.
    93,000km's
    Standard internally except schrick 272/264 cams
    Nissan q45 throttle body
    Bosch 550cc squirters
    Mk4 fuel rail and intake manifold
    1.8L alternator
    12v VR6 coolant system.
    IE egr delete
    Megasquirt 3x ECU
    Best of all
    It will be copping a 75 shot of spray.
    2.25" downpipes and 3" exhaust.
    Walbro 255lph in tank pump.
    The car itself will be nothing special, prothane poly kit front to back, some sort of coilovers, retain power steering this time around hopefully still keep a/c off it.
    Driveshaft shop stage 3 shafts will take the power from the Peloquin LSD, 3.94r&p'd 02a from my vr6 into the 4 lug 9.4" brakes (13" drag slicks up front)
    There will be all kinds of things i will miss that i will drop in to this thread later on. And will continue to update as things go along.
    Nov 2007
    Perth
    Monster!
    Where do you go for the Q45 throttle body?
    Is that a bolt-on affair or will you need adapters?
    Jun 2011
    Quote Originally Posted by tinto View Post
    Monster!
    Will be using an adapter.
    It can be mounted without one, however due to the r32 intake manifold design it won't have the best seal in the world. Plus with the adapter I can bore out the manifold to have a smooth taper.
    Sep 2010
    Southern Highlands NSW
    So good! When do you reckon it will be ready for its first run?
    is that your old vr6 in the garage shot?
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    Jun 2014
    Canberra
    So boss
    Jun 2011
    Only lengthy process left is the wiring loom.
    Had the cliftronix lend a hand yesterday to seal up motor and have it ready.
    Went to spin by hand before putting covers on. Got 1" then locked up.
    Figured something had slipped with timing. So started pulling back down to reset bottom end.
    No frigging clue how this happened. Apparently the vvt gears don't really need the 3.
    Options are machine off run vvt, hope for best. Or to get vvt delete cam gears so oil pressure is not an issue.
    Jun 2011
    Currently having the cams machined true again.
    Purchased these adjustable cam gears from schimmel as well as a water pump.
    Also got a Neuspeed power pulley for pennies.
    Set up the mechanical side of the Nitrous system for now. Bit all over the place but best i can do without getting more braided line made. Will be pretty unseen once there is a 3.5" intake pipe.
    Sweeeeet. Was there any more ideas on what caused the cam damage
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2011
    Likely user incompetence..?
