My mechanic does everything by hand.
Fresh head, TT276 cams, new hg and chains.
All ready to drop in!
Lost my crack pipe. So postponed on all the VR fun
Been doing little things. Finished mounting the 02J shifter.
Degreased all the engine bay. Had 15mm of grease everywhere!
Tucked all the wires i could/be bothered in the chassis legs, rest is inside braided sleeve and tucked away.
Most of the dash installed, along with 3.5 needles in the cluster.
Best of all.
The motor is back at my house. Awaiting it's not so destiny!
He probably has.
No girlfriend means you have to do everything by hand.![]()
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
More waste of time stuff.
Painted the front crossmember, solid front bushings and the trans mount.
Super dodgy once over on the starter
Rear and trans mount brackets in silver. Looks more chrome though!
All in Aussie's finest export. Because all mk3's should be done cheap as possible!
Bitching out on doing the gearbox. But did finally swap over to the 02j selector tower.
quality of shifter feel will be high
Trusty EAA Engineering power steering loop kit in.
Cleaned out the fuel tank before putting the fuel pump housing back in.
