Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: Mk3 Pod/Induction Set Ups.
  1. #21
    Sep 2006
    West Sydney
    Quote Originally Posted by Water Boy View Post
    Is it worth still running the carbon canister?
    Extend the input/output lines with extra hose + connectors and re-route it to the other side. Both left and right sides of the car have the attachment for the charcoal canister.
  2. #22
    Dec 2007
    Ermington, Sydney
    I don't think you can get any better than a cold air intake pipe, or kit. BMC, DRiFT, etc...
    These are enclosed filters with tubes that run down beneath the engine bay for colder air intake. Sounds like the best option to me, and one that despite saying I need to do for over a year, still haven't gotten around to doing
  3. #23
    Feb 2008
    mOOROOLBARK
    this is the photo i had on my computer il post a closer one tomoz
    its a bit of aluminium i cut and folded and then bolted with 2 screws
    its basic but it does keep the heat away
  4. #24
    Dec 2007
    Ermington, Sydney
    Pete are you using a pod on the end of that? If so, how on earth did you get it to fit down there near the horn?
  5. #25
    May 2009
    I have a 95 Vento GL, my airbox is missing its side and i have a K&N panel, sounds good and feels a bit better.
    With the counterflow head design, i fail to see the point of CAI as your inlet manifold is encountering heat soak from the exhaust manifold right below it. But eh each for there own.
  6. #26
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by -88- View Post
    I see what you mean, but:
    Say the heat from the exhaust manifold and gas that is transferred to the inlet manifold air is quantified (given a value). Say 30 degrees celcious is transferred, from the heat of the exhaust (air) to the inlet manifold air.
    Now, if the inlet manifold air temp is say 20 degrees C, with the standard air box, then add the 30 deg C in heat transfer, and total heat of the inlet air is 50 deg C. Now if the inlet manifold air temp is 0 deg C, then add the 30 deg C of heat transfer and teh total heat of the inlet air is 30 deg C, not 50 deg C, which is cooler, & more efficient (basically)
    These are just made up numbers to explain the concept simply. and yes ideally, a cross flow head would have lower inlet temps than a counterflow, but anything you can do to reduce the air inlet temp, should lead to an increase in overall effiency.
    HTH
    edit: welcome to the forum aswell.
    i like volkswagens
  7. #27
    Sep 2006
    Australia?
    The cannister is used for emmisions! You take that out and consider yourself ****ed up the a55hole by the EPA!
    If you think about it the stock box guttered completely is the best option with a panel filter.
    I still have no idea what I am going to run when I get the car up and running.
  8. #28
    Quote Originally Posted by DubSteve View Post
    a dirty great big turbo
  9. #29
    Sep 2006
    Australia?
    Quote Originally Posted by GoLfMan View Post
    Something like that
  10. #30
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by Mrk_Mickey View Post
    yep im running a pod its that bent tube thats holding it there
    its perfect length to wedge in there
