Results 1 to 10 of 14
Thread: Mk3 headlights
    Mk3 headlights
    Got some headlights stock ones from the wreckers and come home to find the interior of the lights are loose? Im guessig this is a common problem? Is there a fix to this?
    The plastic parts are all in tact but it just doest stay and move around. Its getting pretty frustrating haha.
    Sent from my iPhone using Tapatalk - now Free
    Part of the adjusters break from memory. Pretty common
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2011
    Sydney, Campbelltown
    Very very common. if you want a temp fix i suggested blue tac just so it doesn't shake but could always go a step further and body fill if you wanted. But just put em on ! won't bother you if you can't hear it
    Build and learn, not buy and earn.
    Aug 2008
    Mid North Coast NSW
    Yeah adjusters are broken, I aimed my headlights then went crazy with the silicone gun.
    I think you probably have grounds to return them though, worth asking.
    Calling NSW Mid North Coast VW Enthusiasts - Click Below
    Mid North Coast Dub Club
    My question is this. I actually dont mind the rattle but how do I adjust it? Because at the moment it cant be adjusted, can someone tell me if it can be adjusted if I manually open it up and reseal it?
    Can I adjust the reflector myself?
    Quote Originally Posted by Special Air Service View Post
    How did you adjust them with a broken holder?
    Aug 2008
    Mid North Coast NSW
    I just grabbed the back off the bulb/wiring connection & aimed them the best I could. (marked the wall etc). then gentle applied a few big blobs of silicone to hold them in place. once this dried I went crazy with some more silicone. worked out OK for now, will be replacing them eventually as they both have small cracks in them as well.
    So I cant adjust the reflector then place it on the holders and jb weld it?
    And i cant return it. Only store credit returns.
    Aug 2008
    Mid North Coast NSW
    Quote Originally Posted by karjadi15 View Post
    I don't think so...... but you can carefully remove the lens from the front & have a look inside to see whats really going on, but all that did for me was show me that the adjusters were shagged as well as letting me know I wasn't going to be able to fix them.
