Results 1 to 10 of 14
Thread: Mk3 headlights
    Mk3 headlights
    Got some headlights stock ones from the wreckers and come home to find the interior of the lights are loose? Im guessig this is a common problem? Is there a fix to this?
    The plastic parts are all in tact but it just doest stay and move around. Its getting pretty frustrating haha.
    Sent from my iPhone using Tapatalk - now Free
    Part of the adjusters break from memory. Pretty common
    Apr 2011
    Sydney, Campbelltown
    Very very common. if you want a temp fix i suggested blue tac just so it doesn't shake but could always go a step further and body fill if you wanted. But just put em on ! won't bother you if you can't hear it
    Build and learn, not buy and earn.
    Aug 2008
    Mid North Coast NSW
    Yeah adjusters are broken, I aimed my headlights then went crazy with the silicone gun.
    I think you probably have grounds to return them though, worth asking.
    Calling NSW Mid North Coast VW Enthusiasts - Click Below
    Mid North Coast Dub Club
    My question is this. I actually dont mind the rattle but how do I adjust it? Because at the moment it cant be adjusted, can someone tell me if it can be adjusted if I manually open it up and reseal it?
    Can I adjust the reflector myself?
    Quote Originally Posted by Special Air Service View Post
    How did you adjust them with a broken holder?
    Aug 2008
    Mid North Coast NSW
    I just grabbed the back off the bulb/wiring connection & aimed them the best I could. (marked the wall etc). then gentle applied a few big blobs of silicone to hold them in place. once this dried I went crazy with some more silicone. worked out OK for now, will be replacing them eventually as they both have small cracks in them as well.
    So I cant adjust the reflector then place it on the holders and jb weld it?
    And i cant return it. Only store credit returns.
    Aug 2008
    Mid North Coast NSW
    Quote Originally Posted by karjadi15 View Post
    I don't think so...... but you can carefully remove the lens from the front & have a look inside to see whats really going on, but all that did for me was show me that the adjusters were shagged as well as letting me know I wasn't going to be able to fix them.
