Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MK3 Golf 97 Coolant Temperature not moving up
    Nov 2016
    canley vale, nsw
    i turned the hot temperature dial to max. and my feet didn't feel much hot.
    Nov 2016
    canley vale, nsw
    Nov 2016
    canley vale, nsw
    looks so hard to replace the thermostat
    Nov 2015
    It's very easy to fix the gauge.
    You have the gauge on the dash itself which rarely fails, so look at the common first;
    First with what I've read get your thermostat and a proper coolant flush done. Replace the faulty temperature sender at the same time, check the wiring of the sensors & then scan the car, if the sensor is not reading a correct value you will most likely have a fault: Coolant temperature signal implausible etc.
    Regards,
    Josh
    Nov 2016
    canley vale, nsw
    damit the cruise control is dead again few months after i resoldered the pins.
