i turned the hot temperature dial to max. and my feet didn't feel much hot.
looks so hard to replace the thermostat![]()
It's very easy to fix the gauge.
You have the gauge on the dash itself which rarely fails, so look at the common first;
First with what I've read get your thermostat and a proper coolant flush done. Replace the faulty temperature sender at the same time, check the wiring of the sensors & then scan the car, if the sensor is not reading a correct value you will most likely have a fault: Coolant temperature signal implausible etc.
Regards,
Josh
damit the cruise control is dead again few months after i resoldered the pins.
