mk3 gl fault codes. how to get them?
hi guys i wanna get fault codes out of my mk3 gl. wat contacts do i have to bridge to get the fault codes?
im having a problem with starting my car, when i turn the ket to starting position the power starts to fliker or sometimes go dull. the battery, alternator and starter motor r fine. i can push the car to start it this been doin this all week, it doesnt start from last weekend by it self hav to push. and everything resets when i turn the ignition key.
thanks
I don't know how you deduced your battery as fine, but it sounds to me like it's on it's last legs. Our work ute was doing the same thing before we fitted a new battery. As did the fork lift. As for bridging pins, wouldn't have a clue. See if you can't find someone with a VAGCOM cable and a laptop.
Also, before repalcing the battery, make sure you battery teminals are tight, and get the battery onto a charger for a while. You may have a dodgy contack, which is not allowing full current flow from battery to starter, and alternater to battery, hence, bugger all power.
My battery is fine. Iit was fine 1 moment then it was stuffed and the headlights work perfect when the engine is off they not dull or anythin so it wouldnt be the battery and i also cheked it with volt meter just to be sure and its also fine and and i cheked all contacts and relays they all fine so im thinking its 1 of the censors.
Reason: some people could take offence...
We're just checking to see if you've checked it thoroughly - it sounds very much like a battery problem. It could be a faulty ignition switch too - I had power shortages to my stereo, so it could be something to replace. They're prone to failing as it's just plastic.
If you're in the south-west area, Matt from Camden GTI in Campbelltown can help you out with everything including having your car scanned with a VAGCOM. Call him, 0423 051 737.
found wat the problem was. the main wire to the battery was all stuffed on the inside under the insulation, dont know how that pappened, it rusted from the inside
- You may not post replies
- You may not edit your posts
Forum Rules
