Results 1 to 6 of 6
Thread: mk3 gl fault codes. how to get them?
    Mar 2007
    sydney
    hi guys i wanna get fault codes out of my mk3 gl. wat contacts do i have to bridge to get the fault codes?
    im having a problem with starting my car, when i turn the ket to starting position the power starts to fliker or sometimes go dull. the battery, alternator and starter motor r fine. i can push the car to start it this been doin this all week, it doesnt start from last weekend by it self hav to push. and everything resets when i turn the ignition key.
    thanks
    Feb 2007
    Bunyip, Victoria
    I don't know how you deduced your battery as fine, but it sounds to me like it's on it's last legs. Our work ute was doing the same thing before we fitted a new battery. As did the fork lift. As for bridging pins, wouldn't have a clue. See if you can't find someone with a VAGCOM cable and a laptop.
    Feb 2007
    Bunyip, Victoria
    Also, before repalcing the battery, make sure you battery teminals are tight, and get the battery onto a charger for a while. You may have a dodgy contack, which is not allowing full current flow from battery to starter, and alternater to battery, hence, bugger all power.
    Mar 2007
    sydney
    My battery is fine. Iit was fine 1 moment then it was stuffed and the headlights work perfect when the engine is off they not dull or anythin so it wouldnt be the battery and i also cheked it with volt meter just to be sure and its also fine and and i cheked all contacts and relays they all fine so im thinking its 1 of the censors.
    Last edited by golf3; 14-10-2007 at 12:37 AM. Reason: some people could take offence...
    Sep 2006
    West Sydney
    We're just checking to see if you've checked it thoroughly - it sounds very much like a battery problem. It could be a faulty ignition switch too - I had power shortages to my stereo, so it could be something to replace. They're prone to failing as it's just plastic.
    If you're in the south-west area, Matt from Camden GTI in Campbelltown can help you out with everything including having your car scanned with a VAGCOM. Call him, 0423 051 737.
    Mar 2007
    sydney
    found wat the problem was. the main wire to the battery was all stuffed on the inside under the insulation, dont know how that pappened, it rusted from the inside
