Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 83
Thread: MK3: ADZ to AMK to BWS(R36!)
  1. #21
    Jun 2011
    Should look a fair bit more wild with these things in the engine bay too!
  2. #22
    Soooo good. Keen to hear this thing under WOT
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #23
    Jun 2011
    In the spirit of lightness!
    Hacked up the rear of the car.
    Stripped out the interior and fitted up a sparco seat.
    Myles coming in clutch again with a tubular rear beam
    The rear beam is in aid to fit this lightweight rear brake kit. Totalling a whole 7KG for both sides.
    And did a booster delete to finish up all the light weight things
    And a coolerworx shifter to hopefully reduce the shifting dramas I was experiencing last time out.
    Unfortunately I can’t justify spending 12k on a fibreglass front end to improve aerodynamics, so a sheet of conveniently colour matched aluminium will have to suffice.
  4. #24
    nsw
    Jesus Hayden I only just found this thread. Mental! ITB's are amazing even when they're sitting on a bench. Its going to sound brutal. Good work mate.
  5. #25
    brisbane
    Jun 2011
    Cheers boys!
    Can’t wait to hear the VR6 itb doorrrts
  7. #27
    Aug 2006
    Melbourne VIC
    Snuck that shifter in...
  8. #28
    Gone next level H you mad man!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #29
    Jun 2011
    Got some time to get the rear beam finished off. I was sent the wrong wheel bearings so had to pause at the stage of getting it fitted up.
    Quick scuff back and a coat of paint and it’s in. Wheelbase is extended by around 30mm, with ability to extend up to 70mm, provided the tyre clears the rear bumper.
  10. #30
    Jan 2020
    Sydney,NSW
    Great thread, wow what a process and brilliant work. VR6 is a great donk, really like the cold air intake solution.
    Photo above is a significant 'adding of lightness'.
    Good luck with the rest of the journey.
