Soooo good. Keen to hear this thing under WOT
Should look a fair bit more wild with these things in the engine bay too!
In the spirit of lightness!
Hacked up the rear of the car.
Stripped out the interior and fitted up a sparco seat.
Myles coming in clutch again with a tubular rear beam
The rear beam is in aid to fit this lightweight rear brake kit. Totalling a whole 7KG for both sides.
And did a booster delete to finish up all the light weight things
And a coolerworx shifter to hopefully reduce the shifting dramas I was experiencing last time out.
Unfortunately I can’t justify spending 12k on a fibreglass front end to improve aerodynamics, so a sheet of conveniently colour matched aluminium will have to suffice.
Jesus Hayden I only just found this thread. Mental! ITB's are amazing even when they're sitting on a bench. Its going to sound brutal. Good work mate.
Super nice work mate, keep the photos coming...
Cheers boys!
Can’t wait to hear the VR6 itb doorrrts
Snuck that shifter in...
Gone next level H you mad man!
Got some time to get the rear beam finished off. I was sent the wrong wheel bearings so had to pause at the stage of getting it fitted up.
Quick scuff back and a coat of paint and it’s in. Wheelbase is extended by around 30mm, with ability to extend up to 70mm, provided the tyre clears the rear bumper.
Great thread, wow what a process and brilliant work. VR6 is a great donk, really like the cold air intake solution.
Photo above is a significant 'adding of lightness'.
Good luck with the rest of the journey.
