Results 1 to 10 of 10
Thread: Miss fire VR6 - need help
    Jan 2010
    Rockingham, WA
    Hi everyone,
    It started yesterday, when I pull away at low revs, or go arouns a corner and the revs are between 1 and 2 thousand. The car miss fire or hesitate, as soon as it goes over 2 thou it is ok. Dont know what it could be, or if I really should be driving the car like this?
    Any help would be appreciated.
    Jul 2007
    Launceston
    Coilpack? Mine missfired - then stopped when i replaced it (also did leads and plugs at the same time...)
    *shrugs*
    I'm going to the pub... I may be some time...
    Jan 2010
    Rockingham, WA
    Yes, I did the plugs about 1500km ago. Was hoping it not to be the coilpack.
    It only happens about 50% of the time, which makes it even more weird
    Jul 2007
    Launceston
    Mine was an intermittent problem also, did it when it was cold mostly, but sometimes it would just randomly start missing.
    Jan 2010
    Rockingham, WA
    mmmmmm....
    Guess I would have to start looking around for some parts
    Feb 2008
    mOOROOLBARK
    replace your plugs and leads first then if its still missing replace your coilpack
    Jul 2009
    Manly, Sydney
    Try using a MAF cleaner. I cleaned mine out today, i had a hesitation/misfire at around about 3000rpm most of the time, now its drastically reduced, and the car in general runs A LOT better. The cleaner is in an aerosol and not too dear, certainly cheaper than some of the other options. It worked for mine so why not give it a go?
    If that doesn't help i'm not to sure, i've heard oil leaking onto the leads/spark plug connection can cause some issues so maybe look there as well.
    Jan 2010
    Rockingham, WA
    Hi, if it does turn out to be the coilpack, does anyone know where I could get one?
    How much do they go for $$$$$$
    Dec 2007
    Ermington, Sydney
    Could get one from many places. I'd go to GAP because they're decent.
    Jan 2010
    UK Cheshire
    Hi,
    Check the plugs for wear. The gap may look OK but the spark travels from the underside down the insulator so the undesides of the earth fingers wear yet the gap viewed looking into the plug nose looks normal. There should be no real erosion of the under side of each finger. If there is, this can cause misfiring.
    Coil pack? have you thought about repairing. Try searching Google with "vr6 coil pack repair". Quite a few repair offerings to cure the internal spark leakage/breakage of the top insulator cover.
    C.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
