Results 1 to 10 of 1044
Thread: mickey's vr6 thread
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by Mrk_Mickey View Post
    Nah, they're just so I can go lower and have a bit more adjustment. FK konigsports are the go at the moment, but that's not 100% yet.
    Just be aware that your inner clearance from strut to wheel will be reduced with coilovers because the spring will sit lower.
    Oh!
    I also ordered some camber shims for my rear wheels (because I got defected lol) and I might have the guards pumped sometime if the camber isn't enough
    Should have been done aggggggggggggges ago man farout, how many degrees are you going?
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by KI11Z View Post
    Ahh! I'll keep that in mind, cheers brah!
    Probs up to 1.5deg camber...dunno yet, the camber plates are adjustable with toe/camber/both so I'll have a fiddle and see what I can get!
    They're those round things you can get made of plastic or whatever they are lol...does anyone have any advice/suggestions for me? They aren't here yet but when they are I'll take a look at the preset positions on the instructions.
    Sep 2006
    Those camber discs are what I had on the Hecti, not bad, though 1.5 is ef all. Get some fat washers
    Dec 2007
    Ermington, Sydney
    Hahah interesting. No wonder you said they were universal!
    1.5 for me *should* mean about 12mm inwards clearance at the top of the tyre....if I did my geometry anywhere near correctly.
    Dec 2007
    Ermington, Sydney
    Well...
    Apparently VR6 exhausts in America are different! The cat setup must be a different length because the kit I got sent had about 7 inches too much piping from the resonator to the cat. My mate and I tackled my exhaust today and what was going to be a two hour job turned into a lazy 6 hahah. We oxy-torched the middle section apart to start with and unclamped/dislodged the rubber mounts/clamps to remove the old exhaust. After realizing the new resonator piece was too long we cut the end of it off, fit the exhaust up leaving it disconnected to the cat, measured up the pipe and took the resonator off and re-welded it.
    Hooray! I've got a few pics and a clip uploading now.
    Dec 2007
    Ermington, Sydney
    Pics don't work for some reason just yet so here's the video
    http://www.youtube.com/watch?v=2zJrt5oknlA
    May 2009
    sounds tough dude, definitely going to add it to the wish list
