Originally Posted by
Mrk_Mickey
Oh sweet as dude, cheers.
--I did all four control arm bushes with Aydan a little while ago - I'll be sure to check the bolts for tightness. Is torque spec something around 60Nm or so?
--Stretch bolts on the subframe...which bolts are these exactly mate?
--Driveshafts is the last thing in the driveline I think I could check...I've checked my whole hub assembly and all the bolts and stuff there, and I've checked the suspension and the engine mounts. PITA!!! lol
Stretch bolts are the ones that go up the way through the control arms, you will probably find you will get an 1/8th of a turn on them now even after you have tightened them. Vr6 were common for clunks, strut mounts were bad, lowered ones were also bad for Sways hitting the driveshaft. Have you tried it with the sway up out of the way?????
cheers
Jmac
Alba European
