Page 5 of 28 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 271
Thread: Meet the 3 door CL!
  1. #41
    Mar 2011
    Inner West, NSW
    Sure thing buddy! I'll be updating as things come along so just keep an eye on this one
  2. #42
    Mar 2011
    Inner West, NSW
    Took the car to get a wheel alignment this morning. It had positive camber on the front passenger side but they said that in order to fix the problem completely, would be to buy new shocks and springs but that's all good because I shall be getting coils and wheels soon anyway.
    Now, despite all my calculation efforts, I won't be able to make Splendour
    Had George at Ultratune check the car out (such a top bloke - Cheers Dom for recommending) and considering the age, it needs the usual things done; Timing belt & oil filter needs changing. Also rectified the issue with the "rattle" in the exhaust. It turns out the whole system (from the cat) has just disintegrated and I've pretty much got no exhaust haha. Thankfully all the gearbox needs is an alignment from underneath, hence why it's not centring - a bush or spring replacement would have been way too costly at this time and I'm just glad it doesn't need it!
    After all this gets done, that's when the fun begins
  3. #43
    Mar 2011
    Inner West, NSW
    Went to get something out of the car this morning, and the drivers side door barrel has unhooked from the mechanism can still unlock/lock from the passengers side as central locking is still working... Fun times.
  4. #44
    Aug 2012
    Kangaroo Valley, NSW
    I also have that problem, makes for fun times.
  5. #45
    Mar 2011
    Inner West, NSW
  6. #46
    Aug 2006
    Melbourne VIC
    Where did you get that switch?
  7. #47
    Mar 2011
    Inner West, NSW
    strenuous hours of ebaying. Had to find a reasonably priced UK/RHD drive one at that. Some seller in Hong Kong is selling LHD switches for cheap
  8. #48
    Aug 2006
    Melbourne VIC
    Find me one!
  9. #49
    May 2012
    my girlfriends cl has one
  10. #50
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by Water Boy View Post
    Find me one!
    Just checked out the seller I bought mine from, he's not posting worldwide anymore... the bastard. I'll still send you the link and hopefully you can convince him otherwise because I got mine for a deadset bargain. There are none on ebay that are RHD+front fogs; I guess I got lucky.
    GOLF MK3 GTI VR6 HEADLIGHT SWITCH WITH FRONT FOGS | eBay
    Quote Originally Posted by Surfpig View Post
    It came stock with one?! D:
    I also got a #110 relay from california for like 3$, and it turns out it does the exact opposite to what the jumper that's already installed does. relay disables you from using DRL+fogs, stock jumper lets you do all combos...
    So FYI for those of you wanting to install fogs, don't worry about the relay!
