Page 11 of 20 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 198
Thread: me and my mk3
  1. #101
    Mar 2012
    Central Coast, NSW
    Not a constant leak as the stain on the driveway is only a recent thing although I have topped up my coolant three times in my ownership so it's either being used or leaking slowly. Not sure what parts are it as I haven't really done anything with the engine. Been going on the dont fix it if ain't broken yet. Haha. But will definitely be giving it all a massive service now.
  2. #102
    Sep 2006
    Parkinson / Brisbane
    good luck with the diagnosis man, hope it's an easy fix!!
  3. #103
    Mar 2012
    Central Coast, NSW
    Cheers! So do I
  4. #104
    Jan 2011
    Rooty Hill, Sydney
    Nice. If you go down I might come down with you. Get a little convoy going.
    DO IT !!
    Cause then u can meet with the sydney fokes which would then make it 4 vr's from our way an maybe another 1or 2.
    Liking the looks of the possable dish to come !
  5. #105
    Mar 2012
    Central Coast, NSW
    Quote Originally Posted by KKK VR6 View Post
    DO IT !!
    That'd be sick! The only other vr I've ever seen up close is HaydEn's would be sweet to meet up with the Sydney fellas on the way down.
    Cheers mate, hopefully have them on by GAF if the spacers and stuff can get sorted in time. Fingers crossed!
  6. #106
    Jun 2011
    Sounds like a decent enough plan to me. I should order my wider and lower gear..
  7. #107
    Mar 2012
    Central Coast, NSW
    Did a vag com scan today, this is what showed up.
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    37-00 - Faulty
    01247 = EVAP is connected into the air filter I believe and is only an emissions thing. If this is correct than this has been unconnected for ages as I have had a cold air intake connected since I bought it no problems. So that isn't the issue.
    00668 = After some reading can be any electrical related fault. Got a new battery recently so could have been from that or possibly a relay is stuffing up so that's what I'm going to suss out.
    Found the leak and it's oil not coolant. It's leaking from a part to the right of where the oil filter is. Not sure what it's called but there's three nuts with an oil seal around it and there was a little hole in the seal so i just smudged it over. Hopefully someone understands what I mean and can tell me what it is.
    Rolled right rear fender completely flat as I got my hands on a mates heat gun. Not the best job in the world unfortunately. That sums up today!
  8. #108
    Mar 2012
    Central Coast, NSW
    After some research the part that's leaking is the oil cooler. Apparently a common fault, just needs to be tightened or a new seal hopefully.
  9. #109
    Jan 2010
    Melb Westsideeeee
    Looking good, i dig the yellow fogs and also cant wait for the simmons to go on. Keep it up mate
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  10. #110
    Mar 2012
    Central Coast, NSW
    Quote Originally Posted by GeorgeMK1 View Post
    Cheers buddy. Got some orange tint and black coming that I might do the indicators with. Not happy with the finish of nightshade. Fogs are staying yellow though. Simmons are on there way just got to finish up the guards and get the spacers / tyres all sorted.
