There's 3 plugs in back of fuse box, 3 coloured connectors a ground(behind dash) and one blue plug under clam shell to remove the wiring loom from ecu side. Then replace with vr loom.
Brake booster can stay if using 4 lug brakes. If switching to 5 lug will need to change i guess for abs vs non abs? If 3dr doesn't have it.
