Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Maroon VR6 Restoration
    Munno Para West Adelaide
    You would need the engine loom for the vr6 as it would have more wiring for coils ect should be easy enought to unplug and swap over
    Jun 2011
    There's 3 plugs in back of fuse box, 3 coloured connectors a ground(behind dash) and one blue plug under clam shell to remove the wiring loom from ecu side. Then replace with vr loom.
    Brake booster can stay if using 4 lug brakes. If switching to 5 lug will need to change i guess for abs vs non abs? If 3dr doesn't have it.
    Sweet! i was just about to ask re the booster.
    thanks
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
    Update:
    I am about to order my parts hoard from ecs and have a question. Do i have the dual upper chain or the single?
    heres a pic for ref and a pic of the engine number if that helps.
    Maroon VR6 Restoration-12188792_10200934786369034_1320573879_n-jpg
    Maroon VR6 Restoration-12200575_10200934786409035_1176402431_n-jpg
    Maroon VR6 Restoration-12179809_10200934786969049_1176339558_n-jpg
    Jun 2011
    Dual. There's two chains..?
    Want to buy a 2.9 intake manifold and cai?
    How much? (Borat voice)
    Jun 2011
    How much you got?
