Page 9 of 37 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 364
Thread: Mal's Mk3 Build.
  1. #81
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by rayray086 View Post
    Muck around with white balance and you can get the orangey-ness out. Using the filter overlays on photoshop works well OK as well!
    Lol, those 2 aren't too bad, rest are still uploaiding.
    I need photoshop back.
    And a camera.
  2. #82
    Jan 2008
    Quote Originally Posted by schoona View Post
    Possibly favourite shot
    does that thing rub?
  3. #83
    Camden, Sydney
    Well this is the nut I am thinking of removing to bolt those top hats hard up against the body. Thoughts ?
    That Nut attaches to a bearing inside the rubber top hat and holds the spring onto the strut.
    Yours does not do up enough because it is buggered. The bearing is collapsed and the rubber is crushed.
    You need to change the hat and the bearing and then do that nut up tightly with a rattlegun, then put the other cap and nut back on. Then all will be well.
    You should not remove that nut as it is needed for the strut.
  4. #84
    Jan 2008
    Newcastle, NSW
    Thanks matt. So new strut mounts + bearings + rattle gun will fix this issue.
    Just wasn't sure on how to exactly cure the problem.
  5. #85
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by VR6child View Post
    Ahhm yeah it does. Low speed, highway speed. It does. Duckbill has vcopped a few knocks. I don't really like my sump, so I'm trying to take that out also.
    Nah I will raise it on my RDO on friday and get it wheel aligned and hopefully all will be good.
  6. #86
    Mar 2008
    I left my mk2 to rub for a few weeks, and in that time it slowly grazed away at the tyre, then went over a really bad pot hole and it dug this massive chunk out of the tyre. Raised it another few mm that arvo.
  7. #87
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by AusScare View Post
    Yeah I can already see a definite wear pattern as a result of my lowness. Raise on thursday afternoon/evening. Wheel alignment frdiday morning
  8. #88
    Sep 2006
    West Sydney
    Shaved sidewalls FTW.
  9. #89
    Jan 2008
    Newcastle, NSW
    Lol, the sidewalls weren't in the guards. I wish!!!
    9 month old tyres are down to the wear indicators because of the last 2 weeks. Only on the outside, still plenty of meat lefti n the guts of the tyre for safety/grip though...
    Raised it today, though its still tucking a bit at the back....
    And with thanks to Tim, now got a euro lip. It was 60mm offf the deck before i raised it.
    Will get better pics when we go for another shoot
  10. #90
    Sep 2006
    West Sydney
    Get an alignment!
