Page 6 of 37 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 364
Thread: Mal's Mk3 Build.
  1. #51
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by VOLKSMAN View Post
    its looking great , any comments on the ride and feel of your superlow ride?
    all i got to say is try to find some cash and time to sort out the dings around your car.
    Ride, quite stiff lol. Because I have a few things not quite right I haven't been throwing it around too much at all really. The struts I pulled out would not extend at all so they were well shanked, and because of how close it is to the deck im really conscious of going for a b-road bahnstorm. Point being it's a massive change to what I am used to.
    Once these few issues are sorted (see next post), and it's raised with a good wheel alignment, i'll happily find some twisties and see how it goes. Change in power down, weight transfer, pitching under braking etc etc...
  2. #52
    Jan 2008
    Newcastle, NSW
    This is how the front struts sit relative to the body. I don't believe this is "quite" right!
    There is a nut below the body, and instead of using the nylock ones, we reused the old ones because we were a little unsure. They sit up by about a nuts length, so if I remove the lower nut, will that get these strut hats hard up against the body?
    LHS:
    RHS:
  3. #53
    Jan 2007
    ^ same as mine, anyone have any suggestions to what it could be?
  4. #54
    Jan 2008
    Newcastle, NSW
    Those hats that poke up, I just took them off (safe to do so with the car on the deck) and there is a nut underneath. I want these hard up against the body.
    Can get photos of them if oyu want?
  5. #55
    Gosford Central Coast NSW
    mate, they poke up so much because the rubber top mounts are stuffed. you need new ones
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  6. #56
    Camden, Sydney
    Exactly.
    I always change em when installing new suspension.
    I carry them in stock if you are in need.
  7. #57
    Jan 2008
    Newcastle, NSW
    Thanks Aydan
    Weird, stuffed ones would lose their integrity, bulge and sag and carry on wouldn't they?
    Apparently not. Thanks again.
    Big learning curve, haven't touched this before
  8. #58
    Jan 2008
    Newcastle, NSW
    Exactly.
    Thanks Matty, how much you looking for? Any different to the mounts (including bearings)in the link Tim posted earlier? I would assume yours are OEM, and his are to OEM specs?
  9. #59
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by Golf Houso View Post
    We all fixed now.
  10. #60
    Camden, Sydney
    Quote Originally Posted by schoona View Post
    Mine are OEM, including the bearing. His are cheaper, mine need to cost at least $50 each. Either would be better than knackered original ones.
