Originally Posted by
schoona
Not sure when the adapters are arriving as Ian is down at Targa Tasmania this week so I imagine they will come sometime after that.....
The question I have is about tyres.
My question is, sure I will need to work out how much section width I need with a test fit, but how important is the circumference in selecting rubber as I have varying diameters Front & Rear. I can see one would be trying to overdrive the other if they are too far out, but is there a "range" where the effects will be close to nil?
Your front tyres will wear quicker than your rear tyres if they were all rolling the same, so if anything I'd say that smaller circumference tyres on the back will even out the wear as they will need to roll quicker to match the larger circumference.
That said, you probably wouldn't notice the difference bro. The difference between the same tyre on the same wheel, one having a 45 profile and then the other a 40 profile will probably see about....i'm guessing maybe a month or two's difference on a daily driver? But as I said, front wears more anyway so you'll need to fiddle around with tyres before the rears wear completely out.
