Installation is going to be the main problem if you get someone to do it, looks like it may cost you the better part of $1000 to do it![]()
Check out Bildon Motorsport in the USA. Clutch type LSD will cost about $830.00 US.
Dont the Vr6's come standard with an electronic diff lock?
would this item effect your cornering???????
Yes, in that you won't spin up the inside wheel on tight turns and it'll make your arms ache as they fight you, to straighten up when you have your foot down.
VRs often have EDL, which is like it says electronic and IIRC is only a help when you set off from a stand still with one wheel one the loose, it stops working above about 20kmh.
The added expense of an LSD is the main thing that stops me from going forced induction. With that extra power I think you'd have to use an LSD, after paying for the FI don't think I can justify the extra cashWhen I worked out Vortech plus LSD plus install plus bits n pieces not much change from 10k
Forever blowing bubbles.
