Results 11 to 20 of 25
Thread: LSD in a Mk3...
    Quote Originally Posted by Water Boy View Post
    this is the diff which seems to be the fav back home in the uk
    some on ebay for $500 USD
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by velly_16v_cab View Post
    Yeah thats what iv been reading and its talked up heaps on most forums...
    I think its a goer just got to work out if i want to go O2A 4 the multi plate clutch
    Sep 2006
    Australia?
    Installation is going to be the main problem if you get someone to do it, looks like it may cost you the better part of $1000 to do it
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by Mk3vr6 View Post
    Nah thats all good Dad done all his boxes just got to save the coin for the diff
    derochta Guest
    LSD Mrk 3
    Check out Bildon Motorsport in the USA. Clutch type LSD will cost about $830.00 US.
    Vic
    Dont the Vr6's come standard with an electronic diff lock?
    Feb 2008
    mOOROOLBARK
    would this item effect your cornering???????
    Quote Originally Posted by mk3pete View Post
    Yes, in that you won't spin up the inside wheel on tight turns and it'll make your arms ache as they fight you, to straighten up when you have your foot down.
    VRs often have EDL, which is like it says electronic and IIRC is only a help when you set off from a stand still with one wheel one the loose, it stops working above about 20kmh.
    Jul 2007
    Canberra
    The added expense of an LSD is the main thing that stops me from going forced induction. With that extra power I think you'd have to use an LSD, after paying for the FI don't think I can justify the extra cash When I worked out Vortech plus LSD plus install plus bits n pieces not much change from 10k
    Forever blowing bubbles.
    Jun 2007
    Eastern Suburbs Melbourne
    The only thing with a torque biasing diff is dont lift your foot if your up on 2 wheels as the diff will unwind giving u no forward motion and the back end coming round on ya
    and what's wrong with that???
    I've always heard, that all up, you're looking at about 2K+ once it's all done. I wouldn't worry about one till you are runnig major power, ie 20VT or VR6T or something like that.
    i like volkswagens
