Won't get much from scanning it.
Could be a number of things. Sounds fuel or spark related.
Fuel filter, injectors, coilpack, leads and plugs
My vr6 seems to have a loss of power above 3 and 1/2 thousand revs and it will sometimes turn off as im slowing down at a set of lights. It seems to run fine otherwise, it idles fine and everything its just sluggish.
i havnt really checked anything other then unplugging sensors and testing the car had no luck so far.
Gonna get it scanned when i have the time but just wanma see if anyone has had a similar problem and solved it.
The car is a 94 obd1 that hasnt had any mods.
Cheers in advance
Yehh true
Faulty coil packs?
Nahh not a coilpack swapped it over with a mates and still the same
