Cheers and thanks, it looks good from a distance but needs a lot of work (there is a dent in the middle front of the bonnet, a scrap on the driver's corner of the front bumper, the boot lid and bumper have oxidised paint, the rear windscreen seal needs to be replaced, front windscreen scraper is perished as per most Mk3) and that is just cosmetics.
Mechanical to do list from my brother's mechanic:
- breather pipe has a split needs to be replaced
- v-belts need to be replaced
- brake lines needs to be replaced
- brake fluid needs to be bled and replaced
- auto transmission leaking fluid and needs a service
- water pump has a small coolant leak and needs to be replaced
- engine mounts need to be replaced
- all shock absorbers need to be replaced
- left-hand sway bar rubber perished
- rear wheel bearings need adjustment
- air filter needs to be replaced
- ABS has an intermittent fault
- front passenger door lock u/s
- fuel gauge u/s (on the drive back I worked out that it works between full and 1/2, but below 1/2 it intermittently dances between empty and 1/2)
- a couple of the lights in the instrument cluster are u/s
- aircon u/s (unserviceable)
- rear passenger window u/s
