Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: keyring light to led
    Feb 2009
    adelaide
    the globe in the golf key had blown and as it is a weird globe (didnt want to pay a million dollars for a genuine vw one) converted it to a led will hopfully last longer and just as bright
    went to jacar 1.00 for a 3mm white led (think i could of used a 5mm one but didnt realise until i put this in
    had to buy a new battrey the original is a 1.5 v alcaline and the leds run on 3v
    i got a cr1616 lithium coin battery which has the same diameter as the old one it is just a little thinner
    trimed the legs of the led and bent the positive leg at 90 degrees and sloted it into the coper contact part
    i trimmed the negative leg a bit shorter and put that between the spring and a small pice of plastic and it wedged in there nicley
    put it back together and it worked perfectly
    and no soldering
    Feb 2009
    Forest Lakes w.a
    sweet but
    Dec 2007
    Ermington, Sydney
    Mmm once I see pics I'll do this myself!
    May 2009
    Manly, Sydney
    im already on my way to jaycar!
    '95 mk3 VR6Sold
    95 2 Door mk3 VR6
    Quote Originally Posted by Mrk_Mickey View Post
    Ditto Mickey.
    Dec 2006
    Kilsyth, VIC
    I want to see the pics of this one... I tried but got stuck at the battery voltage issue....
    Although to be fair, the alternative just looked that much better and I needed a good excuse to spend some money.
    Although I suspect at only a few bucks for parts there is going to be lots of people VERY interested in getting that light working
    Feb 2009
    adelaide
    in strggle town cant work out how to add pics read the faq but there id no button to add attachemnts from my comp i have put the pic in my gallery if anyone wants to see
    Dec 2007
    Ermington, Sydney
    if you go onto photobucket.com (and sign up if you're not a member already, it's free) you can upload your photo's onto the internet, and then select the 'IMG' link to post as text into here. The picture comes up automatically
    Feb 2009
    adelaide
    you can see the led the positive leg is bent at 90 deg and fits into the slot in the copper contact
    the negative leg is between the spring and a small plastic tab
    the new battery will fit perfectly in the vw button so no need to modify anything
    Dec 2007
    Ermington, Sydney
    Nice work what battery did you use, if there's a number on it?
