Results 11 to 20 of 22
Thread: keyring light to led
    Feb 2009
    adelaide
    it is a 3v litihium coin battery same diameter the part number is cr1616 think it was 2$ at jaycar
    Aug 2009
    Thumbs up 5mm LED
    Quote Originally Posted by redgtd View Post
    the globe in the golf key had blown and as it is a weird globe (didnt want to pay a million dollars for a genuine vw one) converted it to a led will hopfully last longer and just as bright
    went to jacar 1.00 for a 3mm white led (think i could of used a 5mm one but didnt realise until i put this in
    had to buy a new battrey the original is a 1.5 v alcaline and the leds run on 3v
    i got a cr1616 lithium coin battery which has the same diameter as the old one it is just a little thinner
    trimed the legs of the led and bent the positive leg at 90 degrees and sloted it into the coper contact part
    i trimmed the negative leg a bit shorter and put that between the spring and a small pice of plastic and it wedged in there nicley
    put it back together and it worked perfectly
    and no soldering
    Gave this a shot with a 5mm LED. Had to file the LED down because it didn't really fit. Still I think the bigger 5mm is worth it cause it does light the room like a Christmas tree. Also placed a cover over the negative wire to ensure it doesn't contact anything it isn't meant to.
    The copper negative contact to positive spring arrangement is not the best design so I added some electrical tape to the edges (not shown below) to hold the battery in the correct position and provided consistent contact on hold. Otherwise it moves around to much and doesn't connect perfectly every time.
    See photo's below. Thanks to redgtd for the great idea!!!
    Image 1
    Image 2
    Image 3
    I choose blue because that makes this blue tooth enabled right?
    Feb 2009
    adelaide
    that looks awesome may buy a 5mm led and put it in. it does look better and brighter
    Jun 2008
    Western Australia
    Bump, just done mine, can i reccommend getting the 3mm LED, as i spent ages filing down the 5mm one to fit, and even then it does not fit well.
    i would not get the clear white colour, as i don't think it provides as much light as a Blue or other colour.
    and the cost of a new one was $70 according to VW australia
    or i found one on ebay http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    I love this thread, this to me is what forums like this is all about, that is ingenious, so much gain for very little money and effort! and a big F U to the Stealers!
    Goldstar for Redgtd!!!
    May 2007
    Jimboomba. QLD
    Great Thread !
    Hi all,
    This is certainly a great thread. I think this repair/mod would also apply to the MK4s as well, I know that key looks a lot like mine and my light isn't working either.
    Thanks guys
    Pete
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by trauts View Post
    $70 is the cost of a whole new key, not just the bulb. (Of course it's then lots more to have then thing coded to work with your car (if you need it)).
    Jun 2008
    Western Australia
    Quote Originally Posted by The_Hawk View Post
    thats why i said or you can get one on ebay, and it was a link to a whole key not just a bulb...
    May 2009
    The Hillz shire, Sydney
    Just cannot get it to work. 3mm LED just moves around too much!!!!
    Will try again w/ 5mm led.
    Any hints and/or tips?
    1995GolfGlRocketShip!
    Sep 2009
    Quote Originally Posted by Dubdubdubdot View Post
    could try a little hot glue or something
