you need to set up an ignition that involves a proximity sensor for the key, which will be coded to it. You need to do it this way, or someone can just push a button and start your car. But set up thi way, you dont need to put the key in the car - just have it on you.
You should be able to find a kit to retro fit to your car somewhere
