I've tried a continuity tester from each unknown wire to ground and pressing keys on the remote but got nothing. Thought I'd be able to figure them out that way.
Bought the module, unfortunately no instructions on what each wire does.
I have narrowed it down a bit though from searching on forums and what not but I don't have the same one as everyone else.
In order from top to bottom in the photo.
Pink and Orange - Horn and boot release.
These two were thick;
Black - -12V
Red - +12V
Purple - Indicator Flash x2 cables from one pin
Yellow/Black - ?
Yellow - ?
Green and Blue - Windows up/down
Brown - ?
Grey - ?
Any help appreciated, I have found the wiring for the car end so I should be good with regards to that, I just need to figure out the module.
Past - '95 VW Golf MK3 VR6
Finally figured it out.
YELLOW/BLACK - COMMON (ground)
YELLOW - UP (unlock)
GREEN - (not connected)
BLUE - COMMON (ground)
BROWN - DOWN (lock)
GRAY - (not connected)
Phew, now to connect it to the car!
Goof effort. I'm sure it will be a rewarding fit!
Awesome stuff mate.
Red 9N3 Polo GTI (sold)
Mk3 3dr Vr6 Project
lol, had problems.
Fixed them.
New wiring as follows.
YELLOW/BLACK - COMMON (+12V) (White/Red on car)
YELLOW - UNLOCK (green on car)
BLUE - COMMON (+12V) (White/Red on car)
BROWN - LOCK (grey on car)
GREY - (not connected)
last edit and those connections are final and correctly colour coded.
Is this just a cheap eBay module?
Key-less entry is definitely something i want but don't need ahah.
Yeah, bought one from a local seller ~$18 well worth it. Highly recommended. Make sure you have a wire stripper because it means you won't have to cut any wires on the VW cables, very useful.
How the finished product looks. Doubled sided tape to secure the box.
Attachment 12071
I didn't take photos during installation, it was raining and forgot.
Was it an easy install?
My central locking doesnt work but i still think keyless entry would be so handy.
