Cops will give you a hard time about it over here, but by no means illegal.
seriously, add what eva in your engine bay of a vw/audi.. cops wont even bother looking at it.
I have a pod in my engine bay I have used a heat shield that I bought from Supercheap. Its a half shield so not completely covering it does the trick and puts out awesome sound.
On throttle 3000rpm+ you can hear the pod and it sounds like a V8 awesome.
Street racer n:
I have funny ears, so this induction noise thing people go on about... i cant hear it!!
Would it be possible to some how mount a pod filter in original air box to use as heat sheild ? Or am I totally off the track ?
Apart from the sound of pots, in terms of effectiveness, straight pot with heat shield vs panel... similar?
hey mk3vr6 would you happen to have a pic of your set up?
Probably not enough space inside the filter box, theres also nowhere to mount the filter.
A BMC CDA is basically the same thing, with the added touch of ultra-sexy carbon fibre.
yeh buy the bmc or wot i have is d rapidHP.. samething as the bmc except not carbon fiber but metal
A pod has a much bigger surface so naturally its going to suck in more air. The problem is its factors:
- Hot air
- Is it worth it
You also have to look at the fact that if you mount it low where your emmisions canister use to be, there is the chance when it rains that you are going to suck in water and thats a n:
My original setup was a pod sitting in the bottom half of the air box and it fit in that, don't think I have any pics but I will have a look.
Mine has a half heat shield and that seems to do the trick.
