Wind her down a bit
No trouble as in cop trouble?
so I've ran into an issue with my clutch, I noticed the feeling off it change in about an hour and I was just thinking maybe it's just alittle worn down, nek Minnit, drove down the road and I couldn't move, my clutch pedal was retarded and wouldn't spring back up, rolled her back home and now it's munted.
fully pressing the clutch and a thumping sound/vibration happens, and pulling the clutch all the way back up makes this real horrid sound.
Clutch fork/pressure plate fingers
It will be one or the other. Most likely fork. But seen gearbox is coming off you might aswell do clutch change too. Depends how much money you have I'd get a lightweight flywheel too. But usd is ****ehouse atm
Have a look at the clutch pedal but the fact it returns should eliminate a broken clip
